Multisim and Ultiboard
how to remove imported layers from ultiboard general layers property
I imported several .DXF layers into a project some time ago and now they always appear in the default configuration of  every new project. I have tried unsuccessfully to de-select them and set that to the default, but they always pop up again. How can I remove them when there is no facility for doing so in the properties page?
Thanks, Tod
(3,564 Views)
Accepted by topic author Todc.18
Hi Tod,
I think what happened is you imported the DXF layers into a project, then saved the PCB properties as defaults, which then saved the imported DXF layers as defaults. To remove these layers, you need to delete your configuration file, which is where the default settings are stored. This will also reset your user interface and all default settings you have previously stored.
Just follow the instructions here: http://digital.ni.com/public.nsf/allkb/2719D00E36A4D53A8625721300685B3F
I have also created a defect (D116800) because it should be possible to remove these custom layers without resetting your configuration.
Message Edited by GarretF on 01-11-2010 08:25 AM
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,542 Views)
