Multisim and Ultiboard
igbt in multisim
I am very new to multisim .I am trying to simulate IGBT from International rectifier along with resistor and capacitor circuit. I could find and add the IGBT which i require from the library. I would like to switch on and switch off the IGBT with a driver circuit and the internal clock as input to the IGBT gate driver. Kindly suggest me how can i add or make IGBT switch on and switch off with gate drivers or if anz programmable voltage sources available as in LT spice IV
Regards
Sriniketh
(7,460 Views)
Hi Sriniketh
Please have a look into MultiSim examples. I guess the ThreePhaseInverter.ms13 example shows you what you are searching.
The MultiSim examples are located in your public document directory. You should fine the mentioned example under:
C:\Users\Public\Documents\National Instruments\Circuit Design Suite 13.0\samples\Power Conversion\DC-AC
Kind regards,
Andreas
(7,372 Views)
