Multisim and Ultiboard
import and saving wav file in Multisim?
Dear WenR
Actually my problem is to play a audio file in multisim 14. I have designed a audio power amplifer using LM386. Now I need to give a input audio to that amp. If we are going to use a LV user instrument in Multisim then we need to save both LV LLB file and .dll file in the LVInstrument folder of Multisim. I followed your given URL. It is very clear how to make a DLL file. I have a audio file playing LV instrument but after I tried making DLL and LLB it is not got in to Multisim environment. Could you please explain me how to do it
Message 11 of 22
(4,274 Views)
Hello Senaka2014,
Please help to clarify what exactly do you mean with the following statement that you mentioned:
"I have a audio file playing LV instrument but after I tried making DLL and LLB it is not got in to Multisim environment."
Reading through previous insteractions on this thread, I'd like to recommend you to make sure you're following the right steps.
Have you tried to run the example shared by Gorik in previous posts on this thread (making sure to make the changes later suggested by Fernando to make it work in a newer versions of Multisim)? What where your results of this procedure?
Best regards!
Daniel C.
Message 12 of 22
(4,259 Views)
I did all the way you described. But I can't see the player. I'm using Multisim14.
Message 13 of 22
(4,231 Views)
Hello MHbach
As I understand, you know how to create the dll file but you can't get the instrument to appear in Multisim, is that correct?
Could you please explain which specific steps did you followed?
Regards!
Daniel C.
Message 14 of 22
(4,207 Views)
I copied the dll in the folder C:\Program Files (x86)\National Instruments\Circuit Design Suite 14.0\lvinstruments.
Is the problem that I'm using Multisim 14 and the dll was created for an earlier version?
https://decibel.ni.com/content/docs/DOC-28519
Message 15 of 22
(4,145 Views)
Hello MHbach
Correct. Actually as you can see in that link mentioned something about the compatibility. That is the issue in this case.
Regards
Message 16 of 22
(4,133 Views)
can anyone help me to include .wav audio file into multisim using Virtual Audio connector
Message 17 of 22
(3,819 Views)
Check on this 2 links
Playing .WAV files in Multisim
http://digital.ni.com/public.nsf/allkb/A5593A806546635986257B6D0035C67C
Topic: NI Multisim audio input
http://www.diystompboxes.com/smfforum/index.php?topic=72399.0
Message 18 of 22
(3,810 Views)
how can I see the microphone in Multisim? I dont see it within the components...
Message 19 of 22
(2,608 Views)
Hello Can you update this for Multisim 14? I can not run this?
Message 20 of 22
(2,604 Views)
