Multisim and Ultiboard
internal circuit for LM324 Op Amp
how you guys doing ?
I hope you can help me with this , I am not sure i am on the right board for such a question.
the attached picture shows the internal circuit of an operational amplifier LM324. it is used to measure the difference of voltage between 2 input voltages.
I just wanna know how does it do that ?
any help ?
Bill David
(5,702 Views)
Bill David,
That is a fairly standard differential amplifier circuit.  You can look at nearly any basic electronics text to find a description of that or a similar circuit.
Fundamentally, the current through R1 is approximately constant.  That current is split between the two transistors in proportion to their base voltages.  If the voltage at input 1 is more positive than the voltage at input 2, then the current in Q1 increases and the current in Q2 decreases.  A decrease in Q2 collector current produces a smaller voltage drop across the collecter resistor Rc(2) and the output voltage rises toward Vcc.
Lynn
(5,695 Views)
