Multisim and Ultiboard
invisible component
I am going mad! please help.
i am using Multisim 10 and have a wieird problem. I have tried to place a component and once placed it seem to be invisibe.
I tried to check against the properties of a visible placed component, could not see any difference and cancelled the properities box--low and behold THAT had become invisible and the only way to get it back was use the undoo function
any ideas?
(3,790 Views)
Post your circuit... most likely there is a Variant conflict... but is hard to tell without looking at the circuit. Components become grayed-out (not invisible) when they are in a non-active Variant. Or is the component completely invisible?...
Nestor
(3,784 Views)
Thanks foryour reply
Greyed out - but I have given up with it and started again , however perhaps you you can help with something else.
I have copied a connector from the master ultiboard Databaes to the User database and modified it and saved so I know it is there.
When I try to change a Multisim component to use the new footprint the new footprint is nowhere to be seen. How do i make sure that Mulitisim updates the footprint database?
(3,782 Views)
Step 10 of this tutorial shows you how.
Nestor
(3,754 Views)
