Multisim and Ultiboard
keypads in MultiSim 10.1.372 - no MCU
(** This is with the current trial version, ** )
Hello, I'm trying to use any of the keypads in  a "non-MCU"  circuit
I.e.  I copied the keypad,  the Vcc and the ground from the samples Calculator project to a new circuit.
I added probes to each output line of the keypad, and ran the simulation.
Activating any of the buttons does not activate any of the probes.
I created another circuit and added AND gates connected to each keypad output and Vcc, still no output on the probes.
Do the keypads only work with an MCU ?
Mike
(9,294 Views)
Hi Mike,
Here is a drawing for the 4x4 keypad. The attached Mutlisim  file, press the number 7 and the LED should turn on.
Tien P.
(9,264 Views)
Hi Tien,
I can't open your file, as I mentioned, I'm using the 10.1.1 version of the demo,... only downloaded it ~9 days ago, amazing that ver 11 is already out 😉
Anyway, I  figured it out before your post, that I needed to have power applied to a row / or column before pressing a key on the column / row 😉
Mike
(9,258 Views)
