Multisim and Ultiboard
lca110s
Hi guys,
I am developing a pre amp circuit for my experiment. I am thinking of using clare LCA110s  single pole optomos relay in it. Before actually moving to circuit design I was simulating the design on multisim 10. I am unable to find the component.....any suggestions?
thanks
 best regards
sandi
(3,390 Views)
Hi Sandi,
This component is not in our database but there are behavior relay models in our database that you can try.  Select Place>>Component, select 'Basic Virtual' family from the "basic" group and you should find a few relay models.  If this is not what you are looking for, you try using the virtual MOS to create the relay circuit base on the datasheet.
Tien P.
(3,344 Views)
