Multisim and Ultiboard
limit window comparator amp op
Hi
The comparator does not working properly. When I set the input voltage below 5V which is the value of zener diod the output not equal to zero??
any help will be appreciated
(2,888 Views)
Hello Sa05999,
Are you following any example circuit?
Have you tried one of the datasheets circuits?
Diego H
National Instruments.
(2,830 Views)
Thank you, the problem was setting the threshold 5 to 5 overlapped with each other while I am thinking that I am setting it to -5 to 5.
(2,786 Views)
