Multisim and Ultiboard
magnetic core
How do I use the magnetic core (either virtual or not virtual) to model a transformer, and circuit that uses the transformer.  How do I use the non-linear transformer?  What do the pins of the magnetic core connect to.  Are there any examples?  If not can someone provide an example?
ronquan
(3,500 Views)
The magnetic core can be a little cumbersome to use.I will suggest another component if I can understand your requirements.
What effects are you trying to model (e.g is there coil/magnetising inductance and is this inductance linear? leakage inductance)?
Also, what is the configuration (#of primaries, #of secondaries)?
Max
(3,484 Views)
