Multisim and Ultiboard
mq3 sensor and thermistance
i'm going to make an alcohol sensor using MQ3 sensor, but it influenced by temperature, i need to make a compensation using a thermistance but i don't know how. Can you help me ????
Thanks Smiley Happy
(6,885 Views)
You can use components such as voltage control voltage source or voltage control resistor to emulate real-world phenomenal such as temperature.  For example, you can pretend the degree = 1mV so connect a DC source to the input.
Tien P.
(6,877 Views)
OK thanks
(6,872 Views)
I need diagram for the circuit
(6,871 Views)
You can use the Multisim symbol editor to draw part you want. You can access the symbol editor through the Component Wizard under Tools>>Component Wizard.  If you don't need to simulate this part, click "layout" only on step one.  The tutorial to create a new part is here:
http://www.ni.com/white-paper/3173/en/
Tien P.
(6,868 Views)
Dear Tien_P,
Thanks for your reply.
(6,843 Views)
hello where did you find MQ-3 sensor on multism?
(2,707 Views)
