Multisim and Ultiboard
multi-page connections
This is the first time i use the multi-sheet option in multisim and i have a problem. I want to use the same net on different sheets. I know that i need to use off-page connectors to realize this but i can only use 1 off-page connecter per net name per sheet but i need to use more per sheet.
How can i connect different lines to the same net on different sheets? If i use the bus option, i need to draw an offline bus connector and a bus line every time when i want to connect the same nets.
Can someone help me out?
Greets Mike
(6,818 Views)
Hoi,
I've done this before by ending a wire with a junction (just double-click to drop the wire). Then change that wire's net to the one you need. I usually add a note to indicate that it continues on another page.
Dag,
Hg
(6,812 Views)
Accepted by topic author MvdHeuvel
Hai  Hg, (i guess you are from holland ;))
I found a solution. It's possible to use more off-page connectors.
I connected the off page connector to a net and then i renamed the net, not the  connector , and that's it. The funy thing is that when i called NI in Holland they said is is not possible. :S
Mike
(6,803 Views)
Nope, I'm not from Holland but my husband is and I enjoyed living there for a while.
Thanks for the off-page connector tip!
Hg
(6,800 Views)
well, i see you use "Dag" and "Hoi", you must liked it a lot 😉
(6,775 Views)
