Multisim and Ultiboard
multisim 10.1 error
Hi there,
I got a Multisim 10.1 student version that it doesn't launch. The error message says: " An unexpected licensing error has occurred. Contact NI to resolve this issue". Of course, I contacted NI and an engineer instructed me to uninstall and install the software and for the second time, he even went with me throughout the whole process and the same error appears. He didn't have more answer for me after that and said that I should wait for an e-mail response. I have been waiting for that response but I just got an auto-reply with some general info and a referral to this site. I found this forum and I downloaded an .exe for multisim and again I uninstalled and installed the SW but I got the same error. The point is that I need to solve this before this Sunday Jan 25th because I have a lab and a test for school.
I don't know what info would be relevant for you guys to help me out with this. I'm using Windows XP.
Thanks in advance!
(4,971 Views)
Hi;
I'm not sure if this will solve the problem, but you can try cutting the license file from the license directory and just paste it in a new folder you create inside licenses directory and then try to run Multisim. Since the license file may be corrupt you can try doing so, the directory you should look into is:
C:\Program Files\National Instruments\Shared\License Manager\Licenses
Hope the information is useful.
Good Luck
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
(4,927 Views)
Francisco, Thank you so much for your response. I just got tired of trying in my PC and I tried on a different computer and it worked. So, apparently was my PC and not the SW. That was weird though.
(4,906 Views)
