Multisim and Ultiboard
multisim ac analysis for simple resonant circuit gives wrong answer
I tried to run a simulation of the attached simple tank circuit and the multisim results are wrong (don't match hand calculations or microcap simulation results). I tried experimenting with simulation settings with no effect. Can you help me resolve?
-Steve
(6,202 Views)
Hi Steve,
Run attached circuit, I was able to similar results as Microcap.  This screen shot shows the AC setup I used just in case you are not running Multisim 13.
Tien P.
(6,184 Views)
I discovered last night that if I turn on tolerance's, and set the tolerance on the components to zero, then the AC analysis gave the right answer. But, I then turned off tolerance's, and it STILL gave the correct answer. So the bottom line is I lost the conditions that caused the simulator to fail.
-Steve
p.s. I am running version 11
(6,179 Views)
The tolerance doesn't affect the AC simulation. My guess is there is likely a wiring problem, but it's hard to say without looking problem file.
Tien P.
(6,176 Views)
