Multisim and Ultiboard
multisim expression error in Monte Carlo Analysis
I used Multisim’s (ver 10) Monte Carlo Analysis I tried using an expression as the output variable
V(2)-V(5)
and got the message that the output vectors didn’t exist. When I use them individually it worked fine. I tried using the Copy Variable to Expression and Copy Function to Expression method, I tried the double click method, and the just type it in method with the same results each time.
Am I doing something wrong or is it broken?
(3,662 Views)
Mr Analog,
You are doing everything correctly, that feature is having problems but it is already addressed for our next summer update. Once your software gets updated in summer you will be able to enter expressions.
Nestor
(3,654 Views)
