Multisim and Ultiboard
multisim noise simulation
Hello dear NI friends
Recently I found your nice paper:
Noise Analysis Using Analog Devices Operational Amplifiers in Multisim
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGtZCAW&l=zh-CN
In Practical problem part,it seems that there is something inaccurate with the formula seen in the picture below. As far as i am concerned,the numerator shouldn't be 6, it should be:6/(2*sqrt(2)), because 6V is peak-peak voltage Vpp,when we calculate SNR,we should use RMS voltage that is:Vpp/(2*sqrt(2)).Is my opinion correct?
Looking forward to your reply
from
KanHaiSea
(2,017 Views)
Hello KanHaiSea,
Under the article page you will see the feedback window (as in the image attached).
You can click No and then write your report after that NI will handle it.
__________________________________________
Best regards Lyudvig Hovsepyan
(1,972 Views)
-обработка затянется ещё годков на 10, и не факт, что обработается...
Если дружите со spice синтаксисом, то тут вам будет всё понятно...
(1,963 Views)
Hello  Lyudvig Hovsepyan
Thank you very much for your reply!I have been submitted my question as you suggested.
Best regard!
(1,935 Views)
