Multisim and Ultiboard
multisim thermistor model
I need to include a themistor in my circuit but do not know how to build a model within Multisim 9. I have a simple spice model but do not have a clue how to incorporate it into my circuit. I would like to build a component with a specific thermistor characteristic. I ve search the web with not luck and would appreciate any help. Thanks randy
Message Edited by sleepyjake@ameritech.net on 03-29-2007 04:35 PM
(5,911 Views)
If you already have the SPICE model, you can create you own component and add it to the database.  Go to the following link for all the steps to create a new component.
If you this is not what you are looking for, I suggest you use a Voltage control resistor, this component can be found in the Basic Virtual database.  To simulate the non linear characteristic of this component, you can add a non linear voltage source in to control the input voltage
Tien P.
(5,899 Views)
