Multisim and Ultiboard
multisim transformers
hi guys thanks for your time,
i create and test coils, i realy love your program but i mis a few options for the transformers,
first i would like to see on option to change the core to a differant mixes and or air coil,
the wide and shape of the coil and i would like to see more layerd options for excample
this is my latest coil
(4,882 Views)
also i need the gauge of the wires and differand wires like silverplated copperwire
(4,873 Views)
contact me @ pleiadianrecords2@gmail.com
(4,872 Views)
Hi JossStone,
Firstly I wanted to share this part of our site with you, which allows customers to feedback their suggestions directly to R&D. The forums linked below are constantly monitored by our R&D team in the US and they will often respond directly to customer suggestions.
The way they work is that customers can pose a suggestion and other members of the NI community will vote using 'kudos' on whether the idea should be implemented. If the R&D team can implement the suggestion and there is no strong reason not to do it then they will try to implement it for a later release.
MULTISIM AND ULTIBOARD IDEA EXCHANGE
Submit a New Idea
I would like to suggest that you add your idea here, as customer posts carry more weight than internal ones. I'd be happy to give you a 'kudos' point though if you decide to do this.
As an example, here is a post from R&D in response to the LabWindows/CVI suggestions, and list the ideas which actually got implemented into the 2013 release!
https://decibel.ni.com/content/groups/labwindowscvi-user-group/blog/2013/09/04/labwindowscvi-2013-id...
Feel free to post the link if you do decide to create a post.
Secondly a nonlinear transformer can be customized for different applications by using a magnetic core and the coreless coil as the basic building blocks. See the Component Reference Guide page 2-31 for a description and 2-40 for creating coreless coils.
Hope this helps,
Rebecca
(4,775 Views)
Accepted by topic author JossStone
Correction to Multisim and Ultiboard Ideas Exchange Main Page: https://forums.ni.com/t5/Multisim-and-Ultiboard-Idea/idb-p/multisimideas
(4,769 Views)
yes it does thanks
already started a topic just need som kudos https://forums.ni.com/t5/Multisim-and-Ultiboard-Idea/Multisim-transformer-settings/idi-p/3676293
(4,751 Views)
