Multisim and Ultiboard
multisim windows 7 fatal error -fatal error!! Required NIPathsDir property CDS110DIR is undefined
hiii ,I am trying to install multisim and ultiboard student edition in windows 7 .During installation an error pops out and says fatal error!! Required NIPathsDir property CDS110DIR is undefined.Please suggest me a solution.
Techguru
(4,126 Views)
Hi techguru,
When installing Multisim and Ultiboard, you need to be logged in as an Administrator. The issue here seems to be that the installer does not seem to have access to the folder and this can be because of not being logged in as admin. Try to log in as admin and try to install. If there is a firewall in place which could be causing this, you should disable it during installation.
Tayyab R,
National Instruments.
(4,119 Views)
Hi guys! I tried to install the NI Circuit Design Suite 11.0 as administrator, but it didn't work for me. I tried as well to change the default folder "My Documents" to the folder locate on the window path (c:/user...blabla), but no way to work... Anyone has any idea how to solve this bug? Regards, Camponogara D.
(4,008 Views)
