Multisim and Ultiboard
multisim
hi eavery one . so i have multisim 11 version. so i want to find c828 transister . please how can i find that c828 transister ? pls help
(9,250 Views)
Accepted by topic author sameerato@gmail.com
Hi there,
Thank you for your schematic. The C 828 is an old Japanese transistor. Any small signal amplifier with low voltage low current transistor will probably work fine like a 2N3904 or a 2N2222.
Chen_T
(9,243 Views)
dear  Chen_T sir
Thank you very much for help me. So I iam newly of electronic field and subject. I want knowledge that area of electronic circuit.
So how can find  any one equal transistor and  any one electronic parts.
Ex:- C828 TO EQUAL 2N3904 ,2N2222
How can I follow that ? sir
So these days deeply I followed multisim v 11 software for circuit design .but most transistor and ic, resister no in multisim.example: is  that c828 transistor. How can I find that equal parts by multisim software or other methods?
Thank you Chen_T sir
I am sameera
Srilanka-
sameerato@gmail.com
(9,218 Views)
Hi Sameera,
Usually, we download the datasheet of C828 first to see its parameters. Then we can compare the differences between the ones we already known with this C828. Usually for this small signal amplifier application, 2N3904 or 2N2222 is enough.
Chen_T
(9,202 Views)
