Multisim and Ultiboard
multisim
Hello People,
In Multisim I need a bipole to model a superconductor (SC) which follows the equation
Vsc = Vc * ((Isc/Ic)^n)
In which Vsc and Isc are the applied voltage and current respectively, Vc and Ic are parameters to be changed.
Can anybody help?
I tried with the component wizard to import from other bipoles but unsuccesfully.
Thank you in advance.
Reg.
Giancarlo
(5,721 Views)
Hi Giancarlo,
Could you give one or two links to the bipoles you want to import.
And what function is the parameter n.
Regards
Kilian H.
(5,688 Views)
Hi KilianH,
I simply need a bipole that makes:
In which Vsc in the applied voltage and Isc the applied current, that's all.
Possibily Ic must be selectable.
Many thanks.
Regards.
G
(5,683 Views)
Hi G,
what kind of element is a bipole?
In Multisim you can´t search for a special equation of an element. Do you have an example element?
What do you mean by: "I tried with the component wizard to import from other bipoles but unsuccesfully."
Nina
(5,657 Views)
Hi NinaM,
A bipole is an element with two terminals (or legs, pins.....) Like a resistor,
But a Resistor has U=I*R
What I need instead is
U = Uc * ( (I/Ic) ^ n)
where U and I are the applied Voltage and current; Ic, Uc and n are parameters.
Thank you.
Regards.
Giancarlo
(5,653 Views)
Hi Giancarlo,
sorry I overread that you want to simulate a superconductor, so that might be explaining why I don´t know what bipole should be. But is it a real component, which is existing in reality (because I can´t find anything in google) or is it only some theory formula which you need to describe the superconductor?
Generally for a new component you also need a spice model. Normally you could download them at the website of the producer of such one.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH5fCAG&l=en-US
https://www.ni.com/en/shop/electronic-test-instrumentation/application-software-for-electronic-test-...
One other questions might be helpful. That is exactly your goal of your simulation?
Regards
Kilian H.
(5,640 Views)
