Multisim and Ultiboard
my circuit does not working on the realworld
Hi all
My circuit simulation working perfectly on the simulation. But in the real world, it would destroy the input signal and also output completely noise with distortion (input is 1 MHz sine wave, gain is about 40)
I soldering on the PCB and double check the soldering point
Sorry for my bad English
(5,784 Views)
The TI data sheet for the LMH6559 shows a capacitor between R8 and R11. Without that capacitor the DC bias may not be correct.
Lynn
(5,764 Views)
thank you for your kind reply
eventhough if it is not having a buffer. reselt is same as before.
I canot understand the situation
plase help me
(5,759 Views)
Hi, could you explain to me a little bit more of what is it specifically that you are trying to do? Maybe we can work on finding a workaround for it.
(5,757 Views)
I am try to  make a ammplifire with buffer to drive coaxial cabale.
input is connected to the 50 ohm antena and output is connected to the DAQ card
Gain=50-40
I made anothe circuit it also work perfectly on the simulation but not in the real situation. (in put is almost destroted and out put is large noise)
(5,752 Views)
have you got a screenshot of your layout?
Is the 50 Ohm resistor necessary after each opamp? I guess not...
(5,725 Views)
Thank you very much for your kind reply
so that, i am expected to compensate the impedance of the opamp, othe wise for low freqency lot of DC voltage create floting the signal.may be i am wrong
(5,713 Views)
