Multisim and Ultiboard
no interface options
My computers at work have been upgraded.  I installed multisim, ultiboard 10 on my tower and all is good.  I installed it on my laptop and when I run either program it will open, I will have the workspace available, but I don't have any tools or access to any controls to modify the interace (i.e. I don't even have 'file' or 'options').  Anyone know what could be wrong? I've removed and reinstalled already - same problem.
thanks
Ryan
(3,751 Views)
Try this:
  1. Close all Multisim Design Suite 10 if it is currently running.
  2. Navigate to the folder where user interface file is stored, by default it should be in:
C:\Documents and Settings\Your Login Name\Application Data\National Instruments\Circuit Design Suite\10.0\config.
If you don’t see these folders, make sure you turn on ‘Show hidden files/folders’ in the Windows explorer setting, this is under ToolsàFolder OptionsàView
  1. Delete all files in the “config’ folder in the path shown above
  2. Restart Multisim.
Tien
Tien P.
(3,740 Views)
that fixed it - great! thank you
Ryan
(3,737 Views)
