Multisim and Ultiboard
op-amp help for a newbe
Hello all,
 I'm new to Workbench so I like to start by saying, thank for any and all help.
When I used the stranded scope the input sin was the same as the output sine in voltage, but when I tried the Tektronixi scope and put in 1 mv the output was 3.1 volts dc. Could someone tell what may be going. on.
 Ken
P.S. I would like to get an output of  40 khz square  @ 5v
Message 1 of 28
(6,725 Views)
Thanks for posting a picture of your circuit. Could you possibly include your circuit file also.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
Message 2 of 28
(6,710 Views)
HI,
 Is this what you need?
Ken
Message 3 of 28
(6,709 Views)
I don't know if you need this file also.
Ken
Message 4 of 28
(6,691 Views)
I have been fighting with your circuit. I was unable to get any signal from from the first op-amp until I removed C2 and reversed the input connections. I also reversed the connections to the second op-amp. I now have a signal up to D4 and then it just disappears for some reason. It still isn't squaring the waveform though. I don't know if the information I have given is any help. but I thought I would post it for you. I will continue investigating and let you know if I find anything.
Have a Nice Day
Message 5 of 28
(6,679 Views)
I don't know what to tell you on this problem. I have tried putting together integrator and differentiator circuits and I can't seem to get the signal to change from it's orignal form. Maybe someone can give us a clue as to why the op amps won't work as integrators and differentiators or if they have run into a simular sitiation.
Have a Nice Day
Message 6 of 28
(6,661 Views)
Thank you for the help lacy ,
I'm having the same problem with a single stage amp. If you fell like looking at it I've attached a picture and the sim file.
Ken
Message 7 of 28
(6,654 Views)
When I opened and looked at the circuit U1A and U2B were not powered.  Was this missed or did it open wrong on mine?
Peter
Message 8 of 28
(6,648 Views)
It's my understanding that only pins 4 (V+) and 11 (GND) need to be powered on just one Amp. And in the past I did supply power to U1A and U2A unless there was something else wrong at the time.
Ken
Message 9 of 28
(6,641 Views)
That is correct.  For quad op amps only on set of power pins needs to be connected.  U1A will connect U1B, U1C, and U1D.  It will not connect U2A B C or D.  You will notice a red x on all the other power pins once you make the first connection.  Hope this helps.
Peter.
Message 10 of 28
(6,634 Views)
