Multisim and Ultiboard
operational transconductance amplifiers
Where can I find an OTA in Multisim 11? I've tried CA3080 and LM13600 but they aren't with the op amps and I couldn't find them in a search.
Thanks in advance.
(5,730 Views)
I found them. They are under Norton op amps. LM13700
(5,720 Views)
hi. How to simulate an operational transconductance amplifier in multisim? Could give an example.
(5,382 Views)
Yes the C3080 is now LM13700 I would use the N version.
The sim does not show sideband splatter.
To hook up the chip Put power on pin 6,11
Carrier signal on 4   modulation signal on pin 1 (amp Bias)  DC level bias on pin 3  and output on pin 5
Pins 2, 7, 8 are optional
(5,249 Views)
