Multisim and Ultiboard
oscillator
i try to semulate this oscillator circuit,but it does not show any output oscillation from the oscilloscope!!!
can someone advice?..Thanks.
Message 1 of 18
(4,596 Views)
1. Resistor R5 should be more 10К (more, than resistor R2).
2. You have forgotten to connect an output of the amplifier to resistor R5 and capacitor C1.
Message 2 of 18
(4,587 Views)
i hv this circuit for wien bridge oscillator. i want to calculate the gain at different values based on changes in input and output voltage.
how can i make the change in both input/output voltage?
how can i show the oscillation waves  of the gain and frequency,phase and frequency?
Message 3 of 18
(4,576 Views)
this circuit for wien bridge oscillator with  output control,but it is not working!!! may someone help me?
Message 4 of 18
(4,574 Views)
If you put the variable resistor it is necessary to use all 3 pins. Also choose other opamplifier.
Message 5 of 18
(4,569 Views)
thanks alot for your help.i appreciate it.
Message 6 of 18
(4,564 Views)
     i hv another ciecuit for wien bridge passive oscillator and i want to compare the voltage input/output.
what power supply should i use? and how can i see the wave form? in both sides?
Message 7 of 18
(4,561 Views)
For comparison of signals on an input and an output you can use Bode Plotter.
Message 8 of 18
(4,557 Views)
i connect the Bode Plotter but still it cannot run!!
do i need to connect power supply? how?
Message 9 of 18
(4,553 Views)
i am trying to get different values of input/output voltages to compare the change in Gain/phase with respect of frequency changes.
is this circuit correct?
Message 10 of 18
(4,552 Views)
