04-01-2014 11:12 AM
I am trying to use the 19-pin type A HDMI connector for my design. I need to use pin #14, but its not available in Multisim 13.0. Furthermore, the type A HDMI connector is listed as having 18 pins while pin 14 is not listed and pin 19 is there.
How do I change this connector so that I can use the entire 19 pins? Should I use a different connector?
Why would the default connector installed with the product be so awkward?
04-01-2014 03:50 PM
Pin 14 is reserved (N.C.). To simplify the symbol this pin is not listed. If you need this pin you will need to edit this component.
