Multisim and Ultiboard
please help me on this amplitude modulation transistor modulator
please help me on this amplitude modulation transistor modulator  (Solid State AM modulator)
i need a true value for the elelment in the circuit attached below
please help me.........
communication engineering student
(3,881 Views)
Here are some recommendations:
  • Replace all the rated virtual components for real components.
  • Verify the connections of the Signal Generators. On your schematic you are connecting both outputs (positive and negative) to the transformer; the common or neutral terminal is the one located in the middle of the instrument.
  • Verify that the schematic matches your design.
Good luck,
Fernando D.
(3,867 Views)
