Multisim and Ultiboard
positive feedback of a Voltage Controlled Voltage Source component behaves as it would be a negative feedback (no singing)
I don't understand:
I have created a simple feedback on a voltage controlled voltage source component to test the negative feedback.
But as you can see I missed the gain and instead of -1000 I put +1000 into the Voltage gain.
I was very suprised when the circuit worked as if there was a negativ Voltage gain and not positive in the gain field.
The circuit should have behaved as an oscillator. When I changed the +1000 to -1000 the circuit continue the same behaviour.
Can somebody explain me how it could be?
Message 1 of 1
(265 Views)
