Multisim and Ultiboard
print date time
Version 5.7 print the time and date automatic on the bottom of the page when you print the layout in ulticap.
Is this possible in 10.0?
(4,972 Views)
Hello Paul-a,
You can add a circuit description box to your design.
Formatting the Circuit Description Box
You can format the contents of the Circuit Description Box as listed below:
Date and Time Dialog Box
Use the Date and Time dialog box to enter a formatted date and/or time in the Circuit Description Box.
Complete the following steps to place a date and/or time in the Circuit Description Box:
  1. Open the Edit Description window as described in the Circuit Description Box section.
  2. Click at the location where you wish to place the date and/or time.
  3. Select Insert»Insert Date to display the Date and Time dialog box.
  4. Select the desired date/time format from the Available formats list and click OK to place the selection.
Martijn S
NI Netherlands
(4,961 Views)
So this has to be done in each multisim drawing?
It isn't possible in ultiboard  ?
(4,959 Views)
Dear Paul;
You referred to Ulticap, with Ultiboard I found this in the help file;
For each layer you choose to print, you can enable or disable the Outline option to specify whether or not to include the board outline with the layer.
Once you have more than one layer selected, you can choose to print layers on separate sheets. You can also choose to print a header at the top of each page, containing the design name, date, and layer name. Finally, you can use the arrows to change the order in which layers will be printed.
Martijn S
NI Netherlands
(4,945 Views)
