Multisim and Ultiboard
print ultiboard sheet, the name on top of the print
When you print an ultiboard pcb design, the name on top of the print shows the name of the design.
Seems right, but I'm missing the project name.
When I've printed different ultiboard drawings, I've no way of seeing what drawing is from which project.
Is it possible to add the projectname in the text line on the top?
Situation:
Projectname: Test
Design name: part 1
Design name: part 2
Design name: part 3
When I print "part 3", I won't be able to see that's from the project "Test".
(3,567 Views)
Hi Paul,
This is not a setting that can be changed. You can place a comment that can be printed.
Bas
(3,545 Views)
