Multisim and Ultiboard
printing instruments
(3,408 Views)
yeah, and.......
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(3,405 Views)
You need to put some test in the box when making a post so we will have a clearer idea as to what you are requesting.
With that said, there are 2 ways to print the instrument results (if that is what you are wanting). There is an option under FILE>PRINT OPTION>Print Instruments. or you can goto VIEW>GRAPHER and then use the print otion there to print the results. The last one works for the O-scope and other instruments that produce a graph type output. You would have to use the first option for Multimeters, Watt Meter, etc. that produce a numerical output.
If this isn't what your looking for. let us know and we will try something different.
Kittmaster's Component Database
Have a Nice Day
(3,384 Views)
