Multisim and Ultiboard
pulse induction metal detector simulation
I am doing the simulation of the circuit as shown in the attachment. The MOSFET used is IRF9630, however, the library does not contain it and I used IRF9530 to try to replace it. However, when I run the simulation, it always occurs the error. In addition, the monostable Multivibrators chip 74hc221 is used to shorten and delay the clock signal from 555 timer. How can I perform this function in the multisim 14.0 software? Thanks for your help
(2,505 Views)
What is the error that you're getting when you run the simulation?
It might also be helpful if you post your multisim project.
Jonah W
(2,474 Views)
