Multisim and Ultiboard
"Error opening NI-ELVIS-library: "C:\Program Files\National Instruments\NI ELVISmx\FGen.llb" with LabVIEW-Version [12.0.0]"
I can not use ni elvis instruments in Multisim 11. I get the error message:
Hier an overview of the installed software:
I use Windows XP SP2.
Peter
(6,127 Views)
Hi Peter,
I see you installed NI ELVISmx 4.5. This version is not compatible with Multisim 11.x.
Do you have Multisim 11.0 or 11.0.1? In Multisim go to Help>>About Multisim.
I need this info to select the appropriate NI ELVISmx installer.
Best,
Fernando D.
(6,103 Views)
Hi Fernando,
I have Multisim 11.0.2
Best Regards Peter Stolz
(6,099 Views)
Thanks. You should install NI ELVISmx 4.3. It can be downloaded at:
NI ELVISmx 4.3
First you'll need to uninstall (at least) NI ELVISmx 4.5 and NI-DAQmx 9.7.5. If possible uninstall all the National Instruments software (except Circuit Design Suite 11.0.2). After this reboot your computer and install NI ELVISmx 4.3.
Best,
Fernando D.
(6,092 Views)
