Multisim and Ultiboard
"Print as Black&White" still prints color
In multisim 12 and 13 when I select "Print Sheet Setup", "Output options", "In black.white" the bus and bus labels are still printed in color.
The problem with this is that the black and white printer will "blur"  the text and it becomes nearly not readable.
In PDF the bus and bus labels are in color. This is just not nice, since I select black and white.
I tried to make a color schema with black busses and black bus labels but this is not easy because you can not modify or copy the default color scheme...
Anyone as a simple solution ???
Chris.
(5,484 Views)
Hello Chris,
I have Multisim 13.0 installed in my computer and tested an example in it and I was able to reproduce the problem.
Nevertheless, since the PDF file is showing the bus and bus labels in color, a possible workaround is to install a PDF Converter and then print the generated PDF file in black and white.
There are many PDF Converters available, I used CutePDF Writer (free) and got good results with it.
Please let me know if this information helped on your issue.
Leke Raifi
(Intern) Applications Engineer - NI Netherlands
(5,468 Views)
