Multisim and Ultiboard
reagarding simulation error
hi all...
when i'm simulating the circuit...i'm getting o errors and 0 warnings...
but i'm getting simulation error...
errors are:
------ Checking SPICE netlist for 555timercktthreephasefullwavenew - 2009-10-15 17:16:06 ------
======= SPICE Netlist check completed, 0 error(s), 0 warning(s) =======
Error Message From Simulation: doAnalyses: Timestep too small
Error Message From Simulation: tran simulation(s) aborted
i'm changing time step in simulate-->interactive simulation settings-->maximum time step
i'm changing that max time step....but i'm getting the same error...
timestep is small...
how to overcome this problem.......
please help me
(4,096 Views)
Please have a look at the Time Step too Small knowledge base and go try some of the recommendations, it may or may not fix the problem.  Post the Multisim file here if you can, but if the design is confidential, you can send us the file by create a service request at ni.com/ask.
Tien P.
(4,089 Views)
hi...
i tried the settings link which u have given...
but even then my problem is not solved.............
can i get any material related to this error....
i want to read that....
if u can send link then i can download and read...
thank u
(4,076 Views)
