08-31-2011 02:03 AM
hello...Im designing a sensitive vibration detector.But for simulating,I dont know how to put in the relay as shown in the attachment....it says RL 1 6V 100Ω 1C/O relay.I jus want to know how to insert this component in multisim.Thanx in advance.
09-01-2011 12:07 AM
Hi Shirley,
See if this discussion on the forum addresses your query.
http://forums.ni.com/t5/Circuit-Design-Suite-Multisim/Dpdt-Relay/td-p/643542
09-02-2011 10:08 PM - edited 09-02-2011 10:16 PM
In the relay I tried using the one under ELECTRO_MECHANICAL>COIL_RELAY.It has inductance and capacitance values.How to choose that? only the resistance value is known???
And I tried searching this IC: CD4017 but there are different variations in 5V,10V,15V,etc.Can you pls help in selecting the correct one??? The IC is there in the Circuit.
And how to insert the peizo element???
09-03-2011 12:49 AM
also how to insert a piezo sensor???
