Multisim and Ultiboard
see the binary code from a mc14516b-d counter
hey guys, i want to see the binary code that i get from using part 4516BD_5v instead of the signals I get. how could I convert the signals i get to "0" or "1" logic and see the result in 4bits binary code depends on time? TNX
(3,085 Views)
You could try using the Logic Analyzer or the Logic Converter to see the results as 1 or 0 instead of a 5v signal.
Also, you could use the DCD_HEX display to show the result of the 4 outputs as a hexadecimal.
(3,030 Views)
