Multisim and Ultiboard
series parallel resistor max power
hi
i have 3 resistors of different values (22,100,470) but same power rating each 500W. i want to connect them in series parallel way so that each one is used at max power i.e. 500W.
Attached is the circuit i have worked on. supply is 415V and i have each resistor in large quantity.
i have tried other circuits too but this one is consuming most power for each.
if some one else has different ways?
(3,362 Views)
Hi jackferz,
I think the way you have the circuit is the way you can get the maximum power for all the components. I have made a minor change to increase the power being supplied to the 100 ohm resistor. The 470 ohm cannot get more power without the voltage going higher.
Hope this helps.
Tayyab R,
National Instruments.
(3,321 Views)
