Multisim and Ultiboard
show pins
When I put 0.00001 volts the amplitude decreases 😞 Why
Message 11 of 22
(2,776 Views)
Accepted by topic author letitbleed
You have the gain set with the pot such that there is just barely enough feedback for it to sustain oscillation. If you increased the value of the pot it will grow. It will probably grow as you have it set now, you just have to wait long enough.
Message 12 of 22
(2,774 Views)
Wise, indeed, very wise. This has more tricks to it than just component values. Definitively, working at its best just in 0.001 uV and playing with the pot. to push it. Sorry if I am being to buggy but where I live/study there aren't many experienced people in this area to ask stuff...  Is there a way of doing an AC analysis in this? I once did one in a Butterworth filter but can't seem to be able to do it againSmiley Indifferent
Message 13 of 22
(2,770 Views)
You can, but you would need to open the loop. You can do things like leave the 1k connected to the inverting input, sweep that with a function generator and examine the output at the end of the phase shift path. You can then see the phase shift as a function of frequency. Where the phase shift is 180 degrees should be the same as the frequency it oscillates at in your current file. If you open the circuit at the output and drive it through the phase shift network through the RC chain you can see how much gain the circuit has and how it changes with the pot and observed if the value of the pot has any influence on the phase shift and therefore the frequency of oscillation. Analyzing an oscillator by opening up the feedback loop is how RF VCOs are analyzed using software such as Genesys. It allows you to analyzer the Q of the resonator, the gain of the oscillator, the phase shift, etc.
Message 14 of 22
(2,765 Views)
Hello again. Why does anything less than 0.001 uV makes the amplitude actually decrease? Is it not enough impulse?
Message 15 of 22
(2,743 Views)
I reading this on my phone so I can't try it to see. It's probably not enough to overcome the offset voltage on the input of the opamp.
Try increasing the values of all the resistors by 10x and reducing the capacitors by 10x. The frequency will be the same but the amount of current in the feedback loop will be 10x smaller.
Message 16 of 22
(2,740 Views)
How is the gain of this oscillator determined anyhow? Physically I get different values than in the simulation
Message 17 of 22
(2,558 Views)
Do you know by any chance why doesn't my simulation in Simulink doesn't work?
Message 18 of 22
(2,556 Views)
The DC gain is Rf/Rin which in your case is 290k/10k+10k+10k+10k = 7.25.
Message 19 of 22
(2,547 Views)
Can't help you with Simulink, never used it before.
Message 20 of 22
(2,546 Views)
