Multisim and Ultiboard
simulation does not run at all
I have made up some diodes using the component wizard, such that the diode acts like a perfect switch at 0.7 volts.  For some reason SPICE simulation does not run.   If I include one of these diodes in other circuits, the circuit will not simulate.  So the diode model is the problem.   Any ideas how to get it working?  Attached is the multisim file
Thanks in advance!
(6,489 Views)
Accepted by topic author jweaver
"------ Checking SPICE netlist for perfectbridge - Thursday, February 05, 2015, 11:51:34 AM ------
======= SPICE Netlist check completed, 0 error(s), 0 warning(s) =======
Model 'diodeperfect__perfectdiodes__1': Parameter 'IS' must be greater than zero
doAnalyses: Incorrect use of model parameters
Simulation canceled"
So:  Right click on one of the diodes, select "Properties" - "Value" Tab - Press "Edit model" button - Check "Use default" box for "IS" - Press "Change all 4 components" button - Press "OK".
(6,479 Views)
Beautiful !   What did you do to to determine that IS value cannot be zero?  Are you using Multisim to find this error?
thanks again....
(6,448 Views)
Select "View" from top taskbar - check "Spreadsheet View" the window should appear at the bottom of the schematic sheet (unless its been moved elsewhere.  Then run simulation.  Cleck "Simulation" tab in "Spreadsheet View" if it doen't switch to that automatically.
(6,437 Views)
ok, it was hidden.  Found it.  Thanks again
(6,425 Views)
