Multisim and Ultiboard
simulation "iteration limit reached"
I have been trying to simulate a simple circuit. It seems to work ok until I connect a bode plotter and then I get the error "error message from simulation: doAnalyses: iteration limit reached" why is this?
(9,362 Views)
This has to do with with the RSHUNT value that affects high impedance circuits (most often) becuase of this resistance at critical points in your circuit. GO to your simulation settings, through the Simulate drop down menu, and select Interactive Simulation Settings. From there go to the Analysis Options tab and select CUstom Settings. You can change the exponential of RSHUNT to 006 instead of 012. This should work with your simulation.
Cheers,
Miguel V
(9,359 Views)
