Multisim and Ultiboard
sin source modelling with input for phase
There are several AC voltage sources model in Multisim, however none of them allow me to change the ac phase inside a simulation.
The simplest way would be to modify the AC voltage source and add an input for the phase value, but I do not know how to do it.
I am using Multisim 10.1
Best regards
Michel
(4,848 Views)
Hi Michel,
Most AC sources, such as the AC_VOLTAGE source, have more than one phase field; for example, you will often see both a 'Phase' and an 'AC Analysis Phase'.  The 'Phase' field will affect the simulation when running a transient analysis, and the 'AC Analysis Phase' only affects the simulation under an AC analysis.  I would check to make sure that you're using the correct fields.
If you're still having trouble, feel free to post a circuit and we can investigate this further.
Natasha Baker
R&D Engineer
Join the NI Circuit Design Community
Follow Multisim on Twitter!
(4,827 Views)
