Multisim and Ultiboard
slow simulations with signal source
This simulation runs fine but then suddenly stops! Can anyone shed any light on why this may be?
(4,448 Views)
Accepted by topic author pgo48
I did not find that the simulation stops. I found that it significantly slows down when output of XFG1 goes low. This event appears to cause some difficulties for the simulator. Loosening the convergence tolerances helps. Go to Simulate->Interactive simulation settings->Analysis options->Customize. I suggest the following settings:
ABSTOL=1e-8
VNTOL=1e-4
RELTOL=0.01
Max
(4,441 Views)
I have been having the same problem, suddenly slowing down at a certain time. Any suggestions on how to fix this?
(4,393 Views)
