Multisim and Ultiboard
solenoid valve
how can i let output signal from PIC16F887(5v)  shut off the solenoid valve with 24v? . i dont want to connect the solenoid from another power source. i want the same 5V DC for the PIC to be amplified uo to 24 volts. because when the solenoid is connected to the power,it will shut off as it is normally open type. what is the best component can step up the voltage to 24v?
example: FET,TRANSISTOR,OUPTOCOUPLER, LINE DRIVER,RELAY,.....
(3,723 Views)
duplicate post
Please stop the thread spamming. I have no idea why you are asking about PIC products on the NI boards.
(3,720 Views)
