Multisim and Ultiboard
take our design to print it in a remote printer
Hello
How i can take our PCB design to print it in a remote printer
and how i can save our design like an image
(3,969 Views)
Hi, can you check if in Windows you have your remote printers configured?... when in Ultiboard or Multisim you go to File >> Print it shows the available printers configured in Windows. If you want to print to a remote printer (I understand -network) it has to firts be configured in your OS.
Nestor
(3,956 Views)
i am not mean this
i want to take our design like an image  and save it as an image
take it in my flash pin to see it in any computer thats the ultiboard program not install at it
as an image in its  exact  dimention
and by this i can print it like an image
i hope you understand me
how i can do that ??
Message Edited by gsdfg on 05-29-2007 02:30 AM
(3,952 Views)
There are many approaches to this:
a) Use File >> Export... select DXF option... you will need a DXF viewer in the remote machine.
b) Use File >> Print... then select from the printers either:
           b.1) Microsoft Office Document Image Writer (if you have it).
           b.2) Any PDF Printer Driver that you may have installed. You can find several of them if you search on the web for: pdf printer driver.
I guess one of these options may help you.
Nestor
(3,946 Views)
