Multisim and Ultiboard
thermistor and temperature sweep in multisim 14.1
In Multisim 14.1 there are some thermistors. I have designed a simple circuit for evaluating that component in a temperature sweep, but it doesn't work. I've attached the file. Also, in the "Parameter sweep" I don't understand the option "Name", I have only two components but there are 3 options. Can you explain me which is the difference between the two first? I've attached a image with that options.
Is possible a temperature sweep with a NTC?
Regards.
Message 1 of 1
(2,601 Views)
