Multisim and Ultiboard
timestep too small (chopper stabilized amplifier)
Hi All
I am trying to design a chopper stabilized amplifier using Multisim 7.
My circuit works before the amplifer stage. Today, I added a modulator, and every time I simulate, I get a "timestep too small" error message.
I tried increase the end time in transient analysis setting, but nothing works
I attached my circuit to this email, could someone please give me some assistant? I would be really appreciated
(5,060 Views)
Try the steps described in this knowledge base, I hope it will help.
http://digital.ni.com/public.nsf/allkb/4B99B2CD6C0C3B6A86257205005D58E0
I tried simualating your file on and it did not give me any error.
Tien P.
(5,052 Views)
Hi Tien
What verion of multisim are you using? I am using Multisim7
I tried the steps in the knowledge based for fixing the timestep too small problem, unfortunately, it still can't solve the problem
For circuit4, I need to modify my Voltage control voltage source in order to fix the problem.
Now, I add a demodulator to my circuit which is just the same circuit as the modulator. Unfortunatly, I am getting the same "time step too small" problem again
Is there any other way to resolve this problem? I am running out of idea 😞
I attached my circuit with the message,  thanks in advance for your help
(4,952 Views)
I don’t think you will be able to fix this circuit by changing the simulation settings, this looks like a model issue.  I replaced the MOSFET model and this circuit is now running.
Message Edited by Tien P on 04-03-2007 03:33 PM
Tien P.
(4,931 Views)
