10-17-2011 01:20 PM
My question is:I have a diode clipper circuit as shown below in the screenshot. How can I do transient analysis of output voltage between 2 and 0 points?
Thanks in advance.
10-18-2011 02:35 PM
Hi Selahattin,
To look at a node in the Transient Analysis, select Simulate>>Analysis>>Transient Analysis>>Output, you can pick the node you want to look at under "Variables in Circuit" and click the "Add" button, that node will moved to the "Selected variables for analysis" side and when you click the "Simulate" button, all nodes you selected will be analyzed. To simulate node 2 and 0, you only have to select node 2 and Multisim will assume you want to analyze node 2 with respect to ground. If you want to look at the differential voltage between node 2 and 4, in this case, click the "Add Expression" button and you can enter an equation V(2)-V(4).
