Multisim and Ultiboard
transient analysis output
i have problem in transient analysis..  in the output tab.. only have V(1) and V(2).. how should i know which 1 represent which voltage??
how to i obtain the output for voltage across R1 and voltage across C1??
(3,859 Views)
Hi Chris,
Before starting the transient analysis,  double click the wire and it should tell you the node name.  You can also select Options>>Sheet Properties>>Sheet Visibility, check the "show all" radio button do display all net names on the schematic.
To find the voltage drop across the resistor, in the transient analysis, select the Output tab, press add an expression, enter V(2) - V(1).
Tien P.
(3,850 Views)
