Multisim and Ultiboard
trying out Mulisim. Adding PXIe-6363, two connectors
I am trying out Multisim and Ultiboard to see if we should buy it.
I need to connect to the two connectors of a PXIe-6363 through the two ribbon cable connectors it comes with.
If I plce the PXIe-6363 model in Mulisim schematic I can create a circuit i need. All the pins and signal names are there for me.
Wen imported into Ultiboard the connector is a double stack of 68 pin VHJDC-68 connectors.
I need two separate  HD68 SCSI connectors, because this is what is on the other end of the ribbon cable.
Ho do i do that?
I am hoping to preserve the pin names and numbering.
Scientia est potentia!
(5,869 Views)
Hi Magyar,
I don't know if the connector you want to use is Utiboard database but if it is not, you can create one.  Here is the tutorial:
http://www.ni.com/white-paper/5631/en/
Once you have created or located a footprint you need in Ultiboard, edit the schematic syombol and change the footprint.  Have a look at knowledge base:
http://digital.ni.com/public.nsf/allkb/C2B635DEC7163E6286257A3100685238
Tien P.
(5,718 Views)
